1998 Lexus LS400 coilovers
This is vastely debated theme in this forum. Here a few links.
https://www.clublexus.com/forums/ls-...-97-ls400.html
https://www.clublexus.com/forums/ls-...uld-i-get.html
https://www.clublexus.com/forums/ls-...is-better.html
https://www.clublexus.com/forums/ls-...ort-price.html
As you can see. There was already a few discussions about this.
One element would be if you research a certain type of ride. This is not an often debated subject. Also, for example, many of the top contestants recommended on this forum are illegal in Switzerland. Airbags, BC, D2, Megans. No one of the them are allowed on the street. I don't even know what I will be able to choose from when I will upgrade my car.
I looked at D2, Ksport, Megan, and BC. A lot of positive feedback from other folks here on the Megans. Same for the BC coilovers. Personally, I chose the BC BR series for my 2000 and I couldn't be happier for what I paid for them. After damper adjustments, I feel like they ride pretty smooth. I also changed out my rear camber, toe, and traction arms with adjustable Godspeed arms. Also, the BC coilovers are supposed to be re-buildable, from what I've read.
Thank you for your precisions Leeroy. I'm interested in one point. You have also putted different camber, toe and traction arms from Godspeed. What was your goal into taking those mesures ? Wasn't the original arms able to widstand the modification or did you wanted to add the ability to modify the settings of your drivetrains (If I remember right the Godspeed are fully adjustable) ?
If I read you right, you say that those coilovers are giving you a smooth ride, I guess you have the original BC setup of 12k front and 8k rear. But is it firmier than the original coilovers or are they like the same with a lower ride ?
