A question regarding ECU/ECM.
Hello LS owners, I currently own a 2nd gen 1995 LS 400 (UK spec)
The condition of the ECU was already serviced by the previous owner said my trusty mechanic and his scanner can't read the ECU from the 'diagnosis' port. However, the car is operating normally, My question is:
Does the computer smart enough to adapt if i replace it with same gen and year toyota celsior's ECU?
Check the Part number of the Spare ECU and the I can check.
[img]data:image/png;base64,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[/img]
Tom
Tom
Check Part number
Pleas check the partnumber of the spare ECU and then I can verify.
1995-1997 89661-50220
1995-1997 89661-50221
1995-1997 89661-50223
1995-1997 89661-50224
1995-1997 89661-50230
1995-1997 89661-50231
1995-1997 89661-50235
1995 89661-50251
1995-1997 89661-50302
1995-1997 89661-50303
1995-1997 89661-50304
1995-1997 89661-50310
1995-1997 89661-50340
1995-1997 89661-50341
Tom
1995 89661-50251
Tom
1995 89661-50251
Tom
1995 89661-50251
Tom
i ask here first to avoid incompatibility since ECU and travel costs is pretty expensive.
does part numbers you suggested above will work on my car?
Does your car have a hydraulic cooling system?
Diwill05
24
05-22-14 05:10 PM
