Car stalling when tapping on MAF and TPS
You can try changing the ECT. (Engine Coolant Temperature sensor) https://www.clublexus.com/forums/ls-...ange-pics.html
Not saying that is your problem but it is the main sensor, they are known to go bad, and you also say it runs bad at operating temp.
So I replaced ECT sensor today with no change.., didn’t think it was the issue but it was cheap and easy.
ive wondered about it being TPS.. but if tps is always in play then I would have same symptoms in open loop..
which is why I was wondering if TPS is always accounted for or not.
i did play around with tps a little today. And I’ve read that some say your idle speed will change depending on which way you move tps.. mine will temporarily go up or down and aafter a few throttle blips and it’ll always go back to 500. No matter where the TPS is rotated to. Which also makes me wonder if it’s bad. Gonna try to test it tomorrow. Looks tough to do because of location lol
Well PROBLEM SOLVED. It was one of 2 things.
Bad or improperly adjusted TPS.
or gummed up throttle body.
went to try a new (used) TPS I got from a friend. And decided to pull throttlebody as it’s a PITA to properly adjust TPS without pulling it. And was able to clean throttle body it was pretty gunked up. Not horribly like there was issues. But bad enough you could tell it’s never been off after 170k miles. Fired it up and it now has great power no matter the temperature. Thanks everyone for their input
Well done.
Klaus
SC- 1st Gen (1992-2000)
07-09-10 04:16 PM
