Fan shroud issue
Fan shroud issue
Is the fan shroud necessary? Mine is zip tied on and occasionally the fan will hit it..... annoying! Finding a new one seems unnecessary so can i remove it altogether?
BUZZING in radiator/fan area was fan shroud
My daughter drove up with a VERY INTERMITTENT (unpredictable) buzzing sound in the 1991 LS400 under the hood. Sounded like plastic contact kind of thing, and upon removal of cover piece straight above the fan, I was able to see the FAN SHROUD was flapping in the breeze. All 3 (I think) attachment points had failed. Luckily I had some of those foot long zip ties and by drilling a few holes through the shroud I was able to secure it for another 20 K miles I hope! If she leaves it here a week again I may try some JB Weld that someone else suggested! Anyone know if I need to find a point at the underneath to secure also? Thanks!
One of the failed attachments
Strategically placed zip tie (1 of 3)
Looped around a corner to require no drill holes
I epoxied one of mine and its already come loose in just a couple months.Think JB weld sounds like a very good idea.
Edit-I noticed no sign ins for Billydpowe in 5 months.Hope he is OK.
Haven't seen one from Dicer either in quite a while. Hope all the elder members are okay in these times.
You can drive safely at any speed without it but when working on the engine while engine is running is not safe without it.
I swear by JB Weld, it has never failed me any time I used it, even on plastic. (if you surround the whole thing) Zip ties are good for almost everything but if I was you I wouldn't keep it wrapped around that water line, and also that high tech battery hold down bungie cord on the same water line.
As for the bottom of the fan shroud; there's 2 clips on the bottom where it just slides into. You can see it here, #s 18-19. https://www.mylparts.com/oem-parts/l...VkIFByb2R1Y3Rz
Just to keep your daughter safe and not getting stuck somewhere I would check out the power steering pump leaking down onto the alternator. Looks like there's alot of fluid there.
spuds (12-09-20)
