Why Aux instead of BT FM Setup
Hey all
I own a 98 lS400 and looking to add some music connectiivty into it. The LS400 comes with Navi and I was lookin into options to connect my phone and I discovered that factoryRadios based on SR, CA does the job of adding a AUX port into the Tape system for $125 however I also discovered that Anker sells Roav which comes with BT and FM connectivity. Could someone shed some light on both the options in terms of music reproduction? A $125 solution vs $30 solution. The Roav can transmit at 88.x as well which means I can pretty much use that for broadcasting to my deck.
Thanks
Thanks
Hey all
Thanks
Thanks
The Roav sounds like it would work, technically, but the sound quality is gonna be pootastic hopping from bluetooth to FM.
Factory Radio Service can add both aux and bluetooth connectivity to the stock unit. That's what I did, and I use both of them. My phone has a very good DAC, so I get better sound quality from the aux input, but sometimes I prefer to not have wires hanging all over my dash so I use bluetooth. It's nice to have the choice.
I'm not sure I understand what you're asking. Yes, the bluetooth module that FRS adds is internal to the stock head unit. It is spliced into the FM radio input, with a tiny button added to the faceplate to switch between them. It's as close to getting OEM bluetooth capability as you can get.
You mean you can buy a bluetooth dongle that plugs into the aux port? Yeah, I guess you could do that, but if you're going to plug something into the aux port anyway, why wouldn't you just plug your phone into the aux port directly?
Here's the thread about Factory Radio Service adding an aux-in the the FM section of the Nakamichi headunit in the 2000 LS400 I used to have: https://www.clublexus.com/forums/ls-...000-ls400.html
It was absolutely wonderful.
Hey all
Thanks
Thanks
But when you want to listen to an external MP3 player or something, you need to mute others. I still can't find a simple way to mute and I use a home made CD-R which does not contain any audio signal. So I set it in the CD player and select the CD mode to listen to the MP3 player. I connect signals from the telephone and the MP3 players using series resistors each to adjust the audio level as well as to connect 2 different signals. So that makes it possible to listen to the MP3 audio as well as the telephone.
Added MP3 player
inspector1
04-28-22 04:55 PM
xyzzy_dude
07-04-13 07:13 PM
bdan
11-15-11 11:10 PM
