1999 LS400 Ending warranty
Old 07-12-03, 05:33 PM
lsfan
lsfan's Avatar
Default 1999 LS400 Ending warranty
I have 1 1999 LS400 with 41,211 miles that will end the 4 year warranty in 30 days. Altthough I don't know of any problems is there any thing that I should look out for and ask the dealer to check before the warrantly ends?
Old 07-12-03, 10:17 PM
bluestar
bluestar's Avatar
Default Re: 1999 LS400 Ending warranty
I have a '99 as well, but mine has 77K miles....Can't think of anything really... Oh, maybe the outside tilt-down mirror. Is this working properly ? If not, that is a $600 repair if out of warranty. I recall there was a TSB out for the '98 model year that addressed this problem.
With your low miles, the engine has barely been broken in yet So you have many long trouble-free years of use of your LS ahead if properly maintained, of course....
Old 07-13-03, 11:55 PM
BobDana400
BobDana400's Avatar
lsfan:
My '99 warranty expired in February. The telescopic steering system had been showing signs of being sluggish. I had it checked when I would bring it in for oil changes and they would grease it. It went out in April. One service consultant said I was out of luck, but I sent the word out on this forum, and it was suggested that I call the corporate Lexus number. Suffice to say, the telescopic steering system was replaced under warranty, and I am very satisfied in the way Lexus treated me at corporate and at the local dealership. They've got a lifetime customer.
Also, if you're having any problems with "miles since refuel" have them check it and get it on paper (mine will zero-out without refueling about every other month). There was a technical service bulletin out on the fix, but Lexus says the fix is not permanant, therefore, they stopped doing it. If an actual solution comes up they will contact me.
Old 07-14-03, 05:56 AM
Horta
Horta's Avatar
lsfan
Well I asked the same questions to this forum when my 98 was about to run out of warrenty. Fortunatly / unfortunatly our cars are so darn good nothing really breaks this early on. I tried to get things fixed or replaced before warrenty ran out but nothing was needed.
One thing if you have the wood steering wheel and shifter look real good and see if there are ANY hairline cracks in the clear coat. If there are Lexus WILL replace it.
Good Luck
Jerry
LANewsboy
09-24-16 01:26 PM
GrnKouki
CT 200h Model (2011-2017)
10-19-15 10:55 AM
jpl
11-11-13 08:41 AM
Andoskyy
04-04-07 07:42 AM
jsnyder
08-09-02 01:12 AM
Quick Reply: 1999 LS400 Ending warranty
