Starter issues with 95 LS
My 95 LS400 starts and runs great. The problem that some times I turn the key and nothing happens at all. It is as if the battery is completely dead. After a while I can try again and it starts fine. The question is why no response. This only happens occasionly. What part should I look for to fix this?
If when you turn the key and if no noise when it does the problem, it could be an ignition switch going south. If it makes noise then its likely the solenoid going bad as in messed up and burned / corroded contacts in it. And to get to it is removing the starter.
The neutral safety switch is another item to consider when there is no noise.
meanboy
04-22-08 02:22 PM
