Low windshield fluid indicator won’t shut off even though full.
probably the float sensor is clogged, stuck, or malfunctioned. this will require access to the reservoir inside the bumper cover.
you may be able to access the sensor by removing the fender liner from the wheel well.
before you go about removing things, give a firm tap to the bumper with your hand and see if the float unclogs.
Im reading its a common failure and people just unplug it.Thats what they did on mine.
https://www.clublexus.com/forums/ls-...fluid-not.html
Replacement part information:
See 85335 on exploded parts diagram
Lexus P.N.
k well then im not alone then lol. litreally just delt with this exact same thing. low washer fluid message even when filled with washer fluid. i just disconnected it.
