Missing gear shifter piece
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/750x1334/010ef2ec_c677_460e_b1da_f537c97e6487_6c6513aab9d4e0662da79c8341a5d308faaf73cd.png)
can anyone tell me what this part is called that I知 pointing to in the pic.I知 not sure what I would type in on google, I致e tried everything I could think of. Thanks! (Was shifting to hard and it broke so I just took the whole thing out)
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/888405-shift-position-indicator-plate.html
it's a piece of plastic that slides with the gear selector.
you will need to remove the wood panel center console surrounding the shifter to access it.
just pry with a flat head screwdriver starting at the cupholder and work your way forward.
then it wont be an easy slip on, the shifter will probably need to be disassembled as well.
Ltaboso
IS F (2008-2014)
12
05-26-15 09:44 PM
