Coolant Leak Question
Old 06-30-18, 03:05 PM
Superfast1
Superfast1's Avatar
Default Coolant Leak Question
Hi there, I have a coolant leak on my 97 LS400. The level in the coolant reservoir keeps dropping slowly so I have to top it off once every few weeks. There's no puddle of coolant on the ground so it's a small leak. This morning, I've popped the hood to look for the leak & I've found a suspected spot near the firewall (see photo below). I see the coolant residue, it's pretty dried but I believe that's where it leaks. Would like to know if this is a valve where the heater core is connected to & can it be repaired instead of buying a new one? Also, I see a cable attached to the right of this valve. Does anyone know how it works? Thank you
Old 06-30-18, 04:40 PM
Yamae
Yamae's Avatar
As you assume, it is a valve where the heater core is connected. I don't think it can be repaired. Replacing to a new one is the only way to go. The cable is driven by the servo motor which controls the room temperature.
Superfast1 (06-30-18)
Old 06-30-18, 10:06 PM
Superfast1
Superfast1's Avatar
I surfed the net & found out it's called HVAC Heater Control Valve & the p/n is 8724050050. Thanks Yamae.
mstrsltr
GX - 1st Gen (2003-2009)
08-30-18 01:31 PM
pman6
Maintenance
11-17-14 05:48 AM
LexusLoyal
10-30-11 08:47 PM
trez_doz
10-19-10 05:02 PM
azari
01-28-03 05:46 PM
Quick Reply: Coolant Leak Question
