Aftermarket radio
Old 06-30-18, 07:58 PM
99LSprobs
99LSprobs's Avatar
Default Aftermarket radio
im going to replace the stock radio because the backlights that light up all the buttons at night burnt out. If I bought an aftermarket kit like pioneer would I get the ability to set the tones of the sound? Like how the stock has the individual buttons, bass, treble, fader etc. is that possible with aftermarket or only the stock system, thanks!
Old 06-30-18, 08:56 PM
Cruisin101
Cruisin101's Avatar
I replaced mine with a dual din Pioneer last summer and am so happy that I did it. Easiest way to add modern conveniences to a soon to be classic. There is a EQ analyzer that features manual and preset adjustments for you to fiddle with.
I recall reading other posts where the user was no longer able to use the subwoofer amp after converting to a after-market deck. I didn't have this issue, luckily my installer got it to work.
Old 06-30-18, 08:57 PM
99LSprobs
99LSprobs's Avatar
Thank you for info sir
Old 06-30-18, 11:16 PM
EthanS
EthanS's Avatar
Ive had a pioneer 7 inch screen in my 99 LS for years, the equalizer built in to the aftermarket radio should function as long as it is wired up properly, with a good quality harness adapter. My installer got the factory sub to work with the addition of a small aftermarket amp ($80) that fit in the factory amp location under the passenger seat. It sounded great until the factory subwoofer started coming apart.
Old 07-01-18, 10:50 AM
Kansas
Kansas's Avatar
Factory Radio Service can replace your back light bulbs and install an aux-in that allows you to stream whatever you want from your phone. Here's a thread about what they did for the Nak head unit in the 2000 LS400 I used to have: https://www.clublexus.com/forums/ls-...000-ls400.html
I later replaced the Nak head unit with a double-DIN Kenword due the the Nak's right channel dying and not finding anyone to fix it. The Kenword was very nice but I would have rather kept using the OEM head unit.
Here a post about my having the Nak head unit replaced by the Kenwood using the Nak amp and all the Nak speakers: https://www.clublexus.com/forums/ls-...ml#post8219167
Old 07-04-18, 12:47 PM
400fanboy
400fanboy's Avatar
This is what my shop did as well. I think they made a custom harness, they didn't tell me if they got an off the shelf unit or not. Plus they killed matching the interior vynl to the custom surround to the Kenwood unit I got.
Everything works, including sub. I'm probably going to go ahead and replace all the speakers soonish since they're starting to show their age. I had to replace the front pair because the driver door speaker blew, and there's a big difference in sound quality front to back now. And EQ balancing is hard.
Old 07-06-18, 01:13 AM
99LSprobs
99LSprobs's Avatar
I don’t have the NAK system I believe it’s just the pioneer, but it should be the same correct?
Old 07-06-18, 07:20 AM
cyfi66
cyfi66's Avatar
I have a good working factory Pioneer head unit and factory amp that I dont need, PM me if you are interested in purchasing it. I've also added an AUX input to it that has replaced the functionality of the tape deck (set to tape mode to play AUX)
Old 07-06-18, 11:56 AM
99LSprobs
99LSprobs's Avatar
Thank you for the offer but I already picked one up today in Houston! Wish I would have saw this earlier. Installing aux seems hard but there’s lots of threads about it.
jrthomas
RX - 1st Gen (1999-2003)
04-30-18 09:51 AM
KirLexus
10-27-14 11:10 AM
Nissanfan
IS - 1st Gen (2001-2005)
01-08-13 10:09 PM
canon20d
07-06-10 03:47 PM
gs_300
10-04-07 10:52 PM
Quick Reply: Aftermarket radio
