Replacing Hydraulic Fan. What To Use.
Old 07-18-18, 08:12 PM
Moarpower
Moarpower's Avatar
Ok I have a spinning fan on ignition.
Old 07-18-18, 08:15 PM
Moarpower
Moarpower's Avatar
Stupid me forgot to check the orientation of the airflow. Luckily it was just help on by a team zip tie
Old 07-18-18, 11:09 PM
Moarpower
Moarpower's Avatar
Fan and radiator installed and operating correctly.
No I need to figure out these left over hoses and see how the clutch works.
spuds (07-18-18)
Old 07-18-18, 11:48 PM
spuds
spuds's Avatar
Good photos.Following.....
Old 07-19-18, 12:10 AM
Moarpower
Moarpower's Avatar
So with the reservoir removed it enters pimp mode. Need to keep the sensor until I can bypass
Old 07-19-18, 01:07 AM
Moarpower
Moarpower's Avatar
10 mins at idle
Old 07-20-18, 12:07 AM
Moarpower
Moarpower's Avatar
Quick update. Took it for an hour drive in highway and dead stop traffic. Temps stayed very low. Cant hear noticeable volume change in the cabin. Easy job this one. If you have a hydraulic fan on your JDM Celsior and are about to replace any of the assembly, consider this swap.
Old 07-22-18, 06:12 AM
Moarpower
Moarpower's Avatar
So I removed the water pump today and while doing so removed what would be the fan clutch assembly for you guys with non jdm cars.
The clutch assembly on this is quite complicated and made removal for a timing belt job a little different to the ls400
I'll take photos in the morning g for those interested in the difference.
spuds (07-22-18)
Old 07-22-18, 08:25 AM
spuds
spuds's Avatar
great job,very fine info.
Old 07-23-18, 06:11 PM
Moarpower
Moarpower's Avatar
So this is the fan mount as you would have on your ls400 versions. It was pretty complex. So I just removed the clutch plate and pump.
djshadow
Performance & Maintenance
01-16-17 06:17 PM
JspecSC3
04-19-05 01:19 AM
redstar142
GS - 1st Gen (1993-1997)
04-16-04 11:55 AM
gompka
09-28-02 02:00 AM
Quick Reply: Replacing Hydraulic Fan. What To Use.
