1995 ls 400 cranks, but will not start
Was given a 95 LS 400. I have some automotive experience, and have found no spark coming from either distributor coils. Coil wires test good. Any advice appreciated...
I would check fuses, but I am not one to tell you which ones. I would also make sure to disconnect the negative battery terminal for a few minutes and reconnect before trying to start it. If you disconnect anything electrical on a Lexus you have to reset the computer by disconnecting the battery. Otherwise, you will get bad ghostly things occurring. I consider it mandatory. Your donor may have been disconnecting lots of things before your ownership, so I would start be disconnecting the battery. Almost forgot. Do you have a key that is broken? The key fob built into the key? The key fob must be in the very close proximity of the ignition or the security will cause a no start situation.
Hi Michael,
Sorry, forgot to mention, I did check the fuses. #8 10A MIR-HTR, #10 20A HLP R UPR, #11 10A HLP L UPR, #12 10A HLP L LWR, & #13 10A HLP R LWR are blown. also relays?? 40A H/CTRL, & 30A ABS#2 are missing. Key fob is on the key chain, not on the key and works fine. Do you know how to test the ignition coils?
Thanks for the reply
I cracked my first key fob and began having intermittent start issues. I started using the second key, until it broke off in my hand while to starting the car. I dug up the valet key and it started on the first try. However, I did have some coolant temperature sensor issues, and not resetting the computer issues. I will go outside and try to start my car with my broken key fob, now that I have fixed the other issues. I will let you know if it is a no start situation, but my previous attempts having the broken key fob on the chain isn't close enough. I do not know how to test the coils, but a key fob security breach might be cutting off your coils.
So, I just walked outside and tried to start my 98 with a broken key fob and the fob right up against the key. It cranked and would not turn over. I put the valet key in the ignition instead and it fired right up. Do you have another key? Valet key might be in the glove box. If not I would say you are looking at $130 key replacements. This is a known problem and they actually make reinforced keys now. I certainly wouldn't spend $100 on something else, until you have a key that is intact.
When I am saying broken .... I mean broke off...... not to be confused with the lock/unlock etc. aren't working. There is a proximity magnet of some sorts in the plastic housing, and if you try starting the car just with the metal key and the housing is broken. It won't start.
Moikoi
11-04-15 08:25 PM
