Steering wheel tilt motor questions
Old 07-17-18, 08:31 PM
Aytex
Aytex's Avatar
Default Steering wheel tilt motor questions
Hi, so I was looking on the other threads looking to see how I can fix my steering wheel tilt, the motor makes no noise/movement on all axis at all when trying to press the tilt button so do I assume the motor is the problem and not the "quick gear fix" that the other threads say? or could it be a combination of both the gear and the battery?
And if it is the tilt motor's problem is there a link to the part I can find or is it not worth fixing?
Could it possible to manually disconnect the motor and manually adjust the steering column?
(I apologize if this type of question thread already exists and me being too blind to find it )
1999 ls400
Old 07-18-18, 09:08 AM
billydpowe
billydpowe's Avatar
here is your motor, and it has been posted before, keep looking..
Aytex (07-18-18)
Old 07-18-18, 09:16 AM
billydpowe
billydpowe's Avatar
Aytex (07-18-18)
Old 07-19-18, 02:16 PM
Michael88
Michael88's Avatar
When I have trouble with my tilt, I remember placing a washer behind or in front {can't remember which) the white plastic gear in order to line up the gears. Then it works for about 3 years and I have to do it again. Go Figure.
Old 07-19-18, 03:50 PM
billydpowe
billydpowe's Avatar
YOU have an older LS than we do..wvwerybody knows that trick, get a 98 and up and see the new world.
Old 07-19-18, 03:58 PM
Michael88
Michael88's Avatar
I have a 1998 LS400
Old 07-19-18, 04:08 PM
spuds
spuds's Avatar
I have a 1998 LS400
Mine is an Aug 1998 build and also has the old system.98 was the change over year,apparently in later production models..
Old 07-19-18, 04:12 PM
Michael88
Michael88's Avatar
If my memory is correct, I think the gear to place the washer is right behind the joystick is it not?
Old 07-19-18, 06:21 PM
Yamae
Yamae's Avatar
There was a design change to use ultrasonic motors in August 1998 to minimize the noise and the vibration.
spuds (07-20-18)
willcrets
13
02-28-18 05:55 AM
PlatSilvSc
SC- 1st Gen (1992-2000)
12-06-12 09:56 AM
ravig292
08-12-10 11:31 AM
GOLDSc300
SC400 / 300 Classifieds
10-05-04 03:11 PM
jjr1295
05-27-04 07:50 AM
Quick Reply: Steering wheel tilt motor questions
