Temp problem
Old 07-28-18, 05:44 AM
Kal333
Kal333's Avatar
Default Temp problem
1999 LS 400
Temp gauge stays slightly below the 4th marker
Doesnt fluctuate
Just stays there always
I did just flush the system and replace radiator due to a crack.
But the temp still stays above normal or what seems to be normal
Old 07-28-18, 09:49 AM
RA40
Super Moderator
RA40's Avatar
Was the thermostat also replaced? Was the temp gauge at the same spot prior to the fix? May need to be burped. Here ya go:
https://www.clublexus.com/forums/ls-...der-valve.html
haulin79
32
05-24-24 12:31 AM
dheeraj
02-11-14 07:49 AM
MValentine
09-07-13 02:10 AM
shiromori
07-15-06 09:27 PM
messysc
SC- 1st Gen (1992-2000)
12-13-02 03:36 AM
Quick Reply: Temp problem
