Guys i need help finding these bushings
Guys i just hit 250k miles 3 weeks ago . ever since then iv had one after another problem. i feel it kinda weird at exact 250k problem after problem has been popping up. I would fix one thing then aniother problem would happen with in a week. Any ways i decided to go through each suspension piece and test it to see if its good all 4 corner of the car. I got to the rear and found to my suprise all 4 differential bushings are completly shot!!! I put my hand on the drive shaft barley shaking it and the whole assembly moves violently ! The flex shaft bushing has lots of cracks all around it. That stupid rubber bushing with metall collars cost way to much.!
i found that but i cant find the 2 bushings that bolt straight to the drive shaft ears. Laying down you looking right at them. Id like polyurethane if anybody knows where i can get those. Also
2. More bushings that bolt straight ahead in front of the differntal. Poly as well if u can find them iv searched all over the forums and ebay and google .maybe im using wrong words plz put here links if u got them. Thnx guys you always help me when i need it..
If 1998 - 2000 LS400, I had same challenge...and waa able to acquire OEM parts which you refer.
PM me as to your interest.
en11871
02-26-08 08:27 PM
