If my valve cover is leaking, how much do I tighten the bolts to potentially stop it?
#31
The "Reputable" repair shop is dishonest. The valve cover bolt torques spec is EXTREMELY low not to mention 98% of the 400s and 430s on the street have become even looser over time and are only finger tight
#32
This falls somewhere between Highly Unlikely and Impossible. Prob closer to Impossible...
#33
Dishonest? I'd agree, and definitely not someone I'd go back to.
my bolts were literally just loosely sitting in place when i went to give them a gentle snug down... i've read here that the gasket over time shrinks away from the bolts and causes this, is that confirmed? my valve cover gaskets are definitely slowly leaking, although more like 'weeping' since there's never puddles on the ground and the oil level is always good even after 5000 miles... you can smell it though and if you hold a light at the back of the engine it looks like there's steam coming up
#34
#35
spuds (12-15-20)
#37
Bookmarked,thank you bradland.
venomous
13
02-20-12 09:54 AM
