check those sway bar bushings!
Clunking sound
When I've had the problem, a slight clunk was heard when I went around a tight corner. Using a silicon spray, I was able to determine what was causing the noise. It was caused by the worn bushings. I have posted the detail here below.
https://www.clublexus.com/forums/ls-...ht-corner.html
The inside was not badly worn out but this much was enough to cause the slight clunk sound.
Installed them yesterday so the answer to your question is yes.
The old ones were very bad and dry with a lot of play. The sway bar could easily be moved from side to side.
The squeak and crashy suspension in the front is gone and the car feels more stable.
As stated earlier in the thread. Super easy and cheap repair. 4 easy to reach M8 bolts with 12mm heads.
Thanks
Giorgio13 (05-05-19)
Jeffrimerm
Suspension and Brakes
05-18-15 10:43 AM
cmotek24
08-09-09 09:29 PM
