Cooling fan broken 99 ls
Also the temp gauge is like that only when th car is started, once it gets warmed up it goes up to the top 2-3 notches bear read if I keep it on long enough
So I’m not sure if it’s supposed to be like this.... but the fan in front of the radiator is not moving, it’s still, and the car has been over heating, does this only move when driving ? Or is it always supposed to be spinning, here is a pic. Thanks
your car sounds like it overheats at idle ?
make sure you turn the AC on then check if that fan is spinning.
does it overheat without the AC on ?
What is the actual water temp?? In degree's?
GreenUCF20
07-06-12 11:07 AM
