Recapping 91 LS ECU
Recapping 91 LS ECU
I have replaced spark plug wires, 4 O2 sensors, coolant temperature sensor, spark plugs, rotors, distributor caps, timing belt, water pump, EGR modulator. But still my car's mileage didn't improve. Finally today I decide to change all the caps, hopefully this will solve my problem. This job cost 25 dollars. I had to replace 10 capacitors. I have got no prior experience of working of computer motherboard soldering but wherever there is will there is a way. I test drove the car after caps replacement and shift a little bit smoother than before.
AlaskanLS
02-01-19 08:26 AM
