Car Shaking at High Speeds
I second this. @AlaskanLS but would polishing the rotor wont wear out usable surface?
My biggest pain in the rear with my '98 has been getting the front end to ride smooth.
You will need to spend some money . How much depends on how smooth you want it. My replacement list includes:
New ZR rated tires
new factory rotors
new factory pads
Check for bent wheels. machined to true
Strut rod bushings
Rack ends
ball joints.
Steering axle/knuckle/wheel bearing replacement
shocks
And mine is still not as nice as I would like. Yeah , a little frustrating for me. Hope you have better luck.
New ZR rated tires
new factory rotors
new factory pads
Strut rod bushings
Rack ends
ball joints.
shocks
I'm always amazed when forum members talk about "bad" rotors that they think have to be replaced. Brake rotors are only bad when they have become grooved, warped, or "un true" in any way AND too thin to machined. Machining aka turning the rotor removes small amounts of material in a straight and consistent fashion which makes the rotor "true" again. Every rotor has a minimum thickness measurement that the technician uses to determine if the rotor is usable or needs replaced. It is very common for rotors to become grooved or warped and then turned for a 2nd or even 3rd life. Brake shops have been turning rotors for decades! Alaskan I'm not trying to correct you, you have basically said the same thing I'm saying, but "polished" may not be the best term to use. Yes rotors do look polished after they have been machined but the process is a bit more invasive than polishing. I just don't want anyone to take their car into a shop and ask to have the rotors "polished"!
Obviously most members know all about this so this post is for anyone who thinks rotors always have to be replaced or a service advisor is telling you they have to be replaced.
Here's a video that shows the process in detail, set the playback speed to 2x and watch the machine wipe the old metal away...
In my area rotor re-surfacing is $15-20 per rotor . I have never had them re-surfaced, since I can get a whole new set from rockauto for around $110-120 shipped. Even those cheap rotors from rockauto will be better than having yours re-surfaced, New is new - thicker, turned rotors will be thinner and more prone to warping, in my opinion...
correct me if I a wrong
In my area rotor re-surfacing is $15 per rotor or more. I have never had them re-surfaced, since I can get a whole new set from rockauto for around $110-120 shipped. Even those cheap rotors from rockauto will be better than having yours re-surfaced, New is new - thicker, turned rotors will be thinner and more prone to warping, in my opinion...
Bradland,
What rotor would you recommend? I used to have Brembo rotors on my 99 LS, but I don't think they lasted me longer or better than cheap rotors, that's why last couple times I got my inexpensive rotors on Rockauto. I keep using OEM pads, following the notion that good pads are more important and you can get away with cheap rotors if your pads are good...
Any thoughts are appreciated.
Val
Val
Bradland,
Val
Val
As far as rotors are concerned I wish the answer was as easy. Brake parts wear for a wide variety of reasons and to throw a wrench into the works pads and rotors are DESIGNED to wear! I'm no expert but I've never heard a single negative comment on Lexus/Toyota rotors. I would give Lex/Toy serious consideration but It sounds like economy rotors may be the best choice for your driving style. Just don't go too cheap and don't be afraid to have them turned...
Jlacck
13
05-19-17 06:09 PM
KILLERLEXUS
SC- 1st Gen (1992-2000)
09-18-02 08:41 AM
