Outside 'A' pillar trim
Does anyone know how to removed the 'A' pillar trim on each side of the windshield on the outside of the car (mine is a 1998 model year). I might not be using the correct key word search, but so far I believe there may be 3 screws accessible by opening the doors and lifting up the rubber gasket on each side. One of the previous owners touched the driver's side piece, but it needs to be redone.
Super Moderator
Was looking at the 95-97 trim:
https://www.lexussouthatlantaparts.c...category=21743
The 98+ has this one shown:
https://www.lexussouthatlantaparts.c...553450021.html
I've not taken ours off to advise. When the windshield guy was out, he had the trim off so quickly I didn't see how he did it.
Fit1too (10-01-18)
I found this in another post today (by CELSIOR ) so I thought I would put it here. If someone uses my search terms they will be able to find an answer. https://www.clublexus.com/forums/ls-...-moulding.html
Well that didn't work. This is the post with diagram https://www.clublexus.com/forums/ls-...-moulding.html
