May go look at a LS 400 tomorrow have a ? or 2
Wait until you get one. I've been fascinated by cars all my life and have owned over 50 at this point. Toyota vehicles are the best, especially mid 2000 models and back. I have wanted a Lexus since they debuted in 1990. I've been all over mine, under it, had all the wheels off, etc. It is absolutely over engineered. I took it out the other day and really opened it up. I mean this thing will flat out move. There is nothing that sounds nicer than the intake on a 32 valve V8! Some guys like loud, dual exhaust. I like to hear what it's doing, not what it has done. I do like the way our neighbors 5.0 Mustang sounds though!
spuds (10-06-18)
There are also a lot of quirks on these cars.I STRONGLY advise you spend weeks here reading this board,I probably read 1/2 of the entire board it seemed like before I bought.Things like navigation and air suspension are NOT pluses on these cars.
Search the threads on 'Im buying a car,what do I need to know'....those threads are literally worth their weight in gold.PLEASE be patient,a few weeks could be the difference between a car you love and a monster you have to dump after big bux in a year or so.
I went and looked at the 2000 400 LS, it was good for the money but I could not find the service record on the timing belt plus it was not the color I want so I opted out. I like the car however, not junked up with un necessary gadgets and very solidly made for sure and everything worked as it should. I will keep looking..... Thanks for all the help...........
By the way, to me a 430 looks like an old geezer car which is not a problem because I am a geezer!
where in florida are you?? here in orlando yes plenty of them on craigslist but they are all absolutley clapped out and terribly neglected. i hardly ever see them on the road anymore and the few i do see are just barley hanging on for dear life. i assume you must be in South florida, thats where all the nice ones seem to be hiding.
There not a problen to find but you are right the nice ones seem to be south for the most part. I usually take a few months to find real good cars, it took like 2 months to replace my RL with another one that was mint.....
https://fortmyers.craigslist.org/lee...716917266.html
Here you go. If I didn’t have a really nice one I would ****** this up.
41394 miles
DATE: 04/17/2012Repair# 0048188reported by: Scanlon Lexus of Fort Myers
Service: ROAD TEST AND INSPECT. SEE S/C 153 FOR ESTIMATE CLUSTER 1630.00 WITH TAX///description: ROAD TEST AND INSPECT. SEE S/C 153 FOR ESTIMATE CLUSTER 1630.00 WITH TAX/// ~|~CK CLUSTER SPEEDO NOT WORKING CK AND ADVISE//CK ALL THAT IS NOT WORKING FOR DIAG.//// ~|~ESTIMATE W/TAX 1630.00 PLUS OR MINUS/// ~|~ROAD TEST AND INSPECT. SEE S/Show less
25603 miles
DATE: 06/23/2006Repair# 0029424reported by: Scanlon Lexus of Fort Myers
Service: COULD NOT DUPLICATE. TEST DROVE WITH 121.description: COULD NOT DUPLICATE. TEST DROVE WITH 121. ~|~CUST STATES KLUNK WHEN COMING TO A STOP ~|~ ~|~COULD NOT DUPLICATE. TEST DROVE WITH 121.
Service: GAUGE STUCK. LOOSENED NEEDLE. MIGHT STICK AGAIN GAVE ESTIMENT FORdescription: GAUGE STUCK. LOOSENED NEEDLE. MIGHT STICK AGAIN GAVE ESTIMENT FOR ~|~CUST STATES SPEED STUCK ON ZERO LAST WEEK ~|~NEEDS SPEEDO HEAD ~|~GAUGE STUCK. LOOSENED NEEDLE. MIGHT STICK AGAIN GAVE ESTIMENT FOR
Service: INSTALLED NEW BATTERY.description: INSTALLED NEW BATTERY. ~|~CUST STATES KEY IN BAG DOES NOT WORK CHECK & REPORT ~|~ ~|~INSTALLED NEW BATTERY.
Service: REMOVED CALIPER FOR INSPECTIONL. REINSTALLED. NOISE WAS GONEdescription: REMOVED CALIPER FOR INSPECTIONL. REINSTALLED. NOISE WAS GONE ~|~CUST STATES REAR BRAKES SQUEAK IN REV. ~|~BENT SENSOR ~|~REMOVED CALIPER FOR INSPECTIONL. REINSTALLED. NOISE WAS GONE
23716 miles
DATE: 02/09/2006Repair# 0021790reported by: Scanlon Lexus of Fort Myers
Service: LOF COMPLETE.description: LOF COMPLETE. ~|~CUSTOMER REQUESTS LUBE OIL AND FILTER SERVICE ~|~CUST REQUEST ~|~LOF COMPLETE.
Service: NO PROBLEMS FOUND.description: NO PROBLEMS FOUND. ~|~CHECK CAR OVER , BRAKE, BELTS, HOSES ECT. ~|~ ~|~NO PROBLEMS FOUND.
21704 miles
DATE: 04/18/2005Repair# 0006596reported by: Scanlon Lexus of Fort Myers
Service: DONEdescription: DONE ~|~ROTATE TIRES, CHECK SPARE IF IT MATCHES ROTATE ~|~ROTATE TIRES PER CUST ~|~DONE
Service: NONEdescription: NONE ~|~CHECK FOR A SQUEAKING WHEN BACKING UP ~|~POSS BRAKES ~|~NONE
Service: PEREFORMdescription: PEREFORM ~|~ALIGNMENT ~|~REQUEST ALIGN ~|~PEREFORM
20286 miles
DATE: 11/15/2004Repair# 0029820reported by: Scanlon Lexus of Fort Myers
Service: BOTH ITEMS DID NOT GO THROUGHdescription: BOTH ITEMS DID NOT GO THROUGH ~|~CK LOOSE TIRE IF REPAIRABLE OR NOT IF NEEDS REPLACE IT ~|~ ~|~BOTH ITEMS DID NOT GO THROUGH
19697 miles
DATE: 10/06/2004Repair# 0027558reported by: Scanlon Lexus of Fort Myers
Service: PERFORM 4 WHEEL ALIGNMENT.description: PERFORM 4 WHEEL ALIGNMENT. ~|~PERFORM 4 WHEEL ALIGNMENT ~|~ ~|~PERFORM 4 WHEEL ALIGNMENT.
Service: REPLACE 2 WHEELS AND TIRES.description: REPLACE 2 WHEELS AND TIRES. ~|~CUSTOMER HIT SOMETHING ON THE THRUWAY. CAR TOWED IN, GET EST. ~|~ ~|~REPLACE 2 WHEELS AND TIRES.
17588 miles
DATE: 03/05/2004Repair# 0018336reported by: Scanlon Lexus of Fort Myers
Service: CK ALIGNMENT, NO CHARGE TO CUSTOMERdescription: CK ALIGNMENT, NO CHARGE TO CUSTOMER ~|~GODDWILL 4 WHEEL ALIGNMENT ~|~ ~|~CK ALIGNMENT, NO CHARGE TO CUSTOMER
Service: MOUNT AND BALANCE 2 NEW TIRESdescription: MOUNT AND BALANCE 2 NEW TIRES ~|~CUSTOMER PAY FOR 2 NEW TIRES, MICHELIN. ~|~WORN TIRES ~|~MOUNT AND BALANCE 2 NEW TIRES
Service: MOUNTED AND BALANCED 2 NEW TIRESdescription: MOUNTED AND BALANCED 2 NEW TIRES ~|~TIRES ARE FEATHERING ON INSIDE EDGE. GOODWILL 2 TIRES AND CUSTOMER WILL PURCHASE 2 NEW TIRES ~|~FEATHERING TIRES ~|~MOUNTED AND BALANCED 2 NEW TIRES MOUNT AND BALANCE
15098 miles
DATE: 06/12/2003Repair# 0006611reported by: Scanlon Lexus of Fort Myers
Service: description: F.PADS 70% R.PADS 75% TIRE TREAD DEPTH 6/32" ~|~15,000 MILE SERVICE ~|~15,000 MILE SERVICE COMPLETED. ~|~F.PADS 70% R.PADS 75% TIRE TREAD DEPTH 6/32" 15K COMPLETED. 2.0
13109 miles
DATE: 10/25/2002Repair# 0085057reported by: Scanlon Lexus of Fort Myers
Service: description: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX NOTE TO CUST. ROAD TEST CAR 38 MILES ON RT75 FOUND SLIGHT VIBRATION 62+82MPH THELONGER THE CAR WAS DRIVEN THE THE LESS IT VIBRATED. ROAD FORCE VARIATION AND BALANCED 4 DONE TIRES NEITHER WERE OUT OF SPECS AL... Read more
Service: LABORdescription: 80 MPH QUIVER VIBRATION FRONT TIRES ARE NEW AS OF 7/25/02 HWY SPEEDS AT 70 MPH UP TO 80 SHIMMIES 352 REPLACED TWO TIRES 072502 REPLACED 1 TIRE FOR ROAD FORCE VARIATION 08/02 352
12645 miles
DATE: 08/28/2002Repair# 0082915reported by: Scanlon Lexus of Fort Myers
Service: description: VIBRATION AT HWY SPEEDS WE JUST REPLACED FRONT TIRES ON 7/25 352 CAN FEEL IT IN THE FRONT. *RT FRONT TIRE HAD HIGH ROAD FORCE VARIATION. REPLACED TIRE.
12412 miles
DATE: 07/31/2002Repair# 0081949reported by: Scanlon Lexus of Fort Myers
Service: MARK UP SHOULD 45% PARTSdescription: POST TO R.O. 81778
12412 miles
DATE: 07/30/2002Repair# 0081905reported by: Scanlon Lexus of Fort Myers
Service: PARTS BILLED INCORRECTLYdescription: POST TO R.O. 81778
12412 miles
DATE: 07/25/2002Repair# 0081778reported by: Scanlon Lexus of Fort Myers
Service: COMB: EACH ADDITIONAL WHEEL R&Rdescription:
Service: COMB: FRONT CAMBER ADJ ** WARRANTY OPCODE **description:
Service: COMB: FRONT TOE-IN ADJdescription:
Service: COMB: REAR TOE-IN ADJdescription:
Service: WHEEL ALIGNMENT INSdescription: 4WHEEL ALIGNMENT
Service: WHL DISC/TIRE(1 WHL)DISMOUNT R&Rdescription: REPLACE FRONT TIRES UNDER GOODWILL POLICY
11382 miles
DATE: 03/18/2002Repair# 0076453reported by: Scanlon Lexus of Fort Myers
Service: LABOR REPAIRED TIRE IN TRUNK USE AS SPARE ONLYdescription: SPARE IS FLAT
10746 miles
DATE: 01/31/2002Repair# 0074477reported by: Scanlon Lexus of Fort Myers
Service: description: CK FOR WIPERS HITS ON HIGH SPEED.ONLYOUR TECHNICIANS WERE UNABLE TO DUPLICATE THIS CONCERN. THIS CAR IS PERFORMING AS DESIGNED AT THIS TIME. IF YOU ARE STILL CONCERNED, PLEASE FEEL FREE TO ASK FOR A TEST DRIVE WITH ONE OF OUR DIAGNOSTIC SPECIALISTS OR OUR SERVICE MANAGER.
Service: LABOR FOR TILT TELE COLUMN REPLACEMENTdescription: TILT TELE MAKES NOISE
9594 miles
DATE: 11/12/2001Repair# 0071278reported by: Scanlon Lexus of Fort Myers
Service: description: 10K10,000 MILE SERVICE [ ]CHANGE OIL AND OIL FILTER [ ]TOP OFF ALL FLUID LEVELS [ ]INSPECT AIR FILTER [ ]CHECK FOR CHASSIS FITNESS [ ]ROTATE TIRES [ ]VISUAL BRAKE INSPECTION [ ]CHECK ALL ACCESSORIES OPERATION[ ]CHECK OPERATION OF ALL LIGHTS [ ]INSPECT DRIVE BELT(S) [ ]INSPECT BALL JOINTS & COVERS [ ]INSPECT STEERING COMPONETS [ ]BODY INSP.(PAINT, CORROSION) [ ]ROAD TEST FOR PERFORMANCE [ ]ADD BG MOTOR OIL ADDITIVE [ ]WASH AND VACUUM
Service: CURRENTLY AWAITING UPDATED PARTS AND SERVICE BULLETIN FROM LEXUS CORPORATE.description: GROAN IN STEERING WHEEL WHEN INSERTING KEY (8/7/01 194 TILT TELE)
7823 miles
DATE: 08/07/2001Repair# 0067903reported by: Scanlon Lexus of Fort Myers
Service: TSB TSB REPLACE TILT AND TELESCOPING MOTORS.description: STEERING WHEEL MAKES NOISE WHEN TILTING OR TELESCOPING
4404 miles
DATE: 11/15/2000Repair# 0057986reported by: Scanlon Lexus of Fort Myers
Service: description: REPLACE ENGINE OIL AND FILTER CHECK FLUID LEVELS AND TOP UP. INSPECT ALL BRAKE PADS AND DISCS INSPECT FOR PROPER TIRE PRESSURE AND WEAR. BODY AND PAINT INSPECTION,ROAD TEST VEHICLE, WASH AND VACUUM. ******************************** YOUR NEX... Read more
Service: 5000 MILE SERVICE PERFORM TIRE ROTATIONdescription: 5K SERVICE
Service: REPLACED LR TIRE AND BALANCED AND MOUNTEDdescription: NAIL IN LR TIRE SIDEWALL
1022 miles
DATE: 02/15/2000Repair# 0049133reported by: Scanlon Lexus of Fort Myers
Service: description: INSPECT ALL FLUID LEVELS AND TOP UP. INSPECT BRAKE SYSTEM. INSPECT ATF AND DIFFERENTIAL OIL INSPECT FOR PROPER TIRE PRESSURE AND WEAR. BODY AND PAINT INSPECTION,ROAD TEST VEHICLE, WASH AND VACUUM. ******************************** YOUR NEXT ... Read more
Service: 1000 MILE SERVICEdescription: 1000 30 DAY CKUP
10 miles
DATE: 11/16/1999Repair# 0046320reported by: Scanlon Lexus of Fort Myers
Service: NON-OEM LICENSE PLATE AND LEXUS KEY FOBS CHARGED TO VEHICLE.description: TAG
Service: PRE DELIVERY INSPECTIONdescription: PD1
