Door frame hole plug plates
Numerous access holes in the door frame and chassis (such as top of rocker panels below door sills) that are covered with circular thin black or clear vinyl plugs with pressure sensitive adhesive.
Over time, or upon removal, the adhesive loses adherence and they no longer barrier against noise.
As I come across these plugs, I replace them with modified plugs...
The OEM plugs are thin, and thus do not block noise as well as thicker material... however thin is necessary for certain areas due to clearance....
I came up with a solution to offer the best of both worlds.
OEM hole plug \"plates". Two sizes "cover" everything.
Stock hole covers are consistency of packing tape...and do little to block noise.
OEM plug cover plate materialnis much thinner than Boom Mat vinyl barrier material.. Thicker material is more effective sound barrier.
Hole template used to size door access holes...
Plug cut from Boom Mat material .
Boom Mat thick vinyl plug adhesive side is centered and pressed onto adhesive side of new OEM plug. In this way the thicker Boom Mat material resides in hole, while the low profile OEM material adheres to panel surface.
Also....thin plastic on door ECU blocks little sound....
Used same Boom Mat material to create a cover...here the thicker material does not interfere with interior door panel fitment
YODAONE
08-01-18 05:40 PM
gsrthomas
03-10-07 12:26 AM
