unknown parts
unknown parts
I will end this mystery part.. 67774 50020 or 6777? 50030 are trim plates you dont see unles they fall off... they finish the door pouch on each door panel. when/if you use the opening to close the door, your fingers feel them.... cant see them, just feel them.. I am holding one in place,, seem to fit 95-2000..
I discovered these after I purchased my car and got it home. All four of mine were laying in the bottom of each door pocket. I discovered the driver's side first, and then as I started to detail the car, I discovered the others. That is when the light bulb went on and knew what they were for. I glued all mine back in place. They're not on our RAV4s and oftentimes when you try to remove something from the pocket, it will hang in the area where Lexus has these installed.
I think its to cover up the unfinished plastic on the inner lip of the door pocket? I had two of four of mine come unglued with the green putty. I glued mine back with super glue gel and they've been fine since. I've honestly never even put anything in there to even know what these did. I only heard something moving around after they fell off.
onihc
09-10-18 11:24 AM
BinaryJay
09-19-10 08:56 PM
