Guys, pls help... repair manual help
For those that have the repair manual for a 98-2000 LS400, could someone please look up the torque specification for the rear pinion seal? I am replacing it due to slow leak, and it’s critical to get it torqued correctly.
i’d very much appreciate your help.
thanks guys,
Rob from New Hampshire
thanks guys,
Robnh (10-25-18)
Hi, and thank you so much... very much appreciated.
could you possibly show me the torque specs on page SA-83, as noted in diagram?
i do believe that’s the spec i am looking for, and of course, they did not call out that torque spec in the diagramm
as they did on other parts.
i am replacing the oil seal, and that nut at the end of assembly is the torque spec i need.
i so much appreciate your help.
thanks,
rob
thanks,
rob
Mind you this is from auto-zone, so buyer beware:
[b=left]LS 400 And LS 430[/b]- Remove or disconnect:Gear oil Driveshaft Companion flange Oil seal and slinger
- Install or connect:NOTEOil seal drive-in depth: 0.079 inch (2.0mm).Oil slinger New oil sealMulti-Purpose (MP) grease to the oil seal lip Companion flange on the shaft Gear oil on the threads of a new nut. Torque to 80 ft. lbs. (108 Nm).
- Adjust the drive pinion preload as necessary, stake drive the pinion nut, and install the driveshaft.
- Fill the differential with hypoid gear oil
