91 ls400 v8 no power to fuel pump
The car was running when parked but there is no power to fuel pump have checked fuel pump relay efi relay all fuses good under dash wires don't have any marks that I can see any suggestions?
Did you check the Circuit Opening Relay?
The little jail cell is your coolant or temperature warning. So something is wrong if this light stays on when the car starts. This light will switch off when the car is running. Mine is lit up when ignition only is on.
