LS400 - Wont start - Fuel issue
I know treads have been started previously but I cannot find the information im after or in terms i Understand, my Apologies
My celsior/ls400 has been neglected in my garage the past 12 months due to other commitments and now wont start
Does start when sprayed with starter fluid but dies as soon its stopped
Fuel pump does not prime
EFI relay clicks but fuel relay does not click
Im lost on what or how to test from here on, any assistance would be appreciated
Thanks
Thanks
Thanks
Thanks
1, No signal from the MAF for more than 3 seconds.
2, No signal from the crank position sensor for more than 5 seconds.
3, No signal from the cam position sensor for more than 5 seconds.
4, No IGF signal from the igniter for more than 3 seconds although the IGT signal is sent.
The link below may help you to know how the power is sent to the fuel pump although it's for a 98-00. Other generations are a bit different but mostly the same.
https://www.clublexus.com/forums/ls-...ml#post7719776
Yamae,could those issues you list be related to a long term dead battery then trying to start with a low battery after time? Just curious....Thanks.
Thanks Yamae
Also i have tried starting while brigding the b+ and fp on the diagnostic with no luck
I believe this would bypass the circuit opening relay or am I incorrect
The battery while now drained was 12v when attempting originally
https://www.clublexus.com/forums/ls-...ml#post9338445
spuds (12-01-18)
A long term dead battery sometimes causes strange problems. You can find the detail at below.
If so, there is a possibility that the ECU was malfunctioning caused by stray electrons due to the very slow voltage drop.
FALLOUT18
03-07-19 09:18 AM
ZGagnon
32
05-23-14 08:12 PM
porshapowe
02-24-07 08:36 PM
