Alternator problem need help
Okay so I woke up today, and went out to test the battery it was exactly 12v. I took the battery to auto-zone for replacement because the battery is still under warranty.
Then thanks to spuds, RA40 I did the test and I found there was a 1.4A draining. Then I found two fuses 1 of them MPX-B is little bit confusing because when I took it out the drain dropped to 150mA, and when I put it back in it came back to 1.6-1.4A and then just intensely kept dropping to 150mA. The other fuse OBD this one is my fault for leaving the obd2 scanner in there. When I removed the obd it dropped to 30mA. thanks everyone who helped me fix this problem.
Congrats!!
Lexus813
04-20-12 01:28 PM
