Newbe in need of some help climate not working
Hi guys am new to the club i have lexus ls400 gen2 2000 model i cant figure out this issue in need of some help please
i have no climate control working its fozen on a/c mode on screen with a weird flashing demister button on too. Nothing is working not even a/c even though its button selected. Its the touch screen stereo model with sat nav, everything on the unit works radio sat nav.. But climate control, once u push climate button to go to climate screen theres no fan ,no heat, no touch screen responding on climate screen, but on every other screen functions everything works ie sat nav radio so on. I checked all fuses and found the 7.5 a/c fuse keeps blowing under steering wheel changed it blows again, switched relays under bonnet no change, i uplugged a/c plug on a/c pump no change still blows, i toke ecu out and fuse box to check any leaks ie caps or water ingress nothing . I got car plugged in on diagnostics showed no faults but not reading a/c unit as think cause fuse is blown. Please can someone help cant drive my car as windows fog up and its super cold .. Many thanks
cheers for reply buddy cars never had any work done since i owned it & was working no issues before , i couldnt find much info out there of similar issue its weird everything on unit works bar climate, if i could get fuse to stop blowing i think climate will work.. well i hope cheers
The 7.5A AC fuse supplies +B 12V to the A/C computer and servo motors. The important first step is to check those finding which one is drawing the big current. The problem is that it is not easy to access those because those are under the dash.
hi again is the a/c computer control the heat and fan speed ie reply what does it look like and cant see any links pics out there for gen2 ls400 location of servo motors .does a/c control everything ?
I replaced capacitors in mine....it seems to behave better (when pressing "ON" button there is more consistency of what comes on...like air conditioning compressor that I did not activate...) and replace climate control bulbs;
See:
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/855424-1995-2000-ls400-climate-control-capacitors-and-backlighting.html
Imspect, clean and, or, replace your temperature sensor
See:
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/846574-interior-temperature-sensor-1995-2000-ls400.html
I'll provide updates if I find a solution, but my 1996 LS climate control system appears to have died today. The screen has illumination, but that is it. Outside Temperature indicator also reads _ºF... The fan has stopped, AUTO does nothing, even the defroster is unresponsive... I checked a bunch of fuses and things appear to be fine otherwise... I need to keep looking...
MK4Sup_isF
08-11-13 09:38 PM
dough boi
SC- 1st Gen (1992-2000)
02-01-06 10:37 AM
