I don't know what but not sure if my 97 ls400 crankshaft seal is leaking
My 97 ls 400 is leaking oil and it is everywhere i am not sure if it is a crank seal leak or it is leaking somewhere from top any guesses what could possibly can go wrong???
If the crank seal is bad then it could be replaceable ? Or i need buy another motor?
And if any of these seals are bad then the only possible fix, is to replace the engine.
I am joking all the seals are replaceable and there are OEM parts available.
This happened on my 97' LS shortly after purchasing it at 253k, I think 2k miles later I had an oily mess on my hands. Don't let it get really bad, otherwise it'll coat your timing belt in oil and you'll be forced to basically do a TB/WP change. But in order to replace it, you'll have to remove the belt regardless so its best to do the belt anyways for preventative maint.
