So I got cheap tires lol
I've got Bridgestone Ecopia EP422 plus' that the previous owner put on 2k miles before I bought the car and I've never had a tire so quiet before, not even Michelin Defenders. I was also able to get 32mpg on the 150 mile drive home after buying the car.
https://www.discounttire.com/buy-tir...2-plus/p/29711
But why not spend 40% more for a 85k mile rated tire vs. 40k mile rating that's better quality like a Yokohama Avid Ascend? It'll most likely start out with more tread which should isolate road NVH much better and a longer lasting compound that'll not dry rot as easily as the cheap Chinese or Korean made tires.
https://www.discounttire.com/buy-tir...ascend/p/43879
Probably and that comes with the price paid. If these keep the car roadworthy then the price accomplishes that. If you want more characteristics that typically comes with a price. Americas Tire is good so if not happy see what they can do on a different tire.
I put some Yokohama Avid Envigors on the Corolla and they are pretty decent in that level of A/S tire. Reasonably quiet, acceptable traction and good enough for the So. Cal conditions that don't have snow or freezing temps. Not wallet ripping in that particular size of 195/60-15 either. I had been looking for the Goodyear A/S that is also in the same category. The Yokohamas were on sale so that swayed me. Drive that car sub 7K annually so I'll be replacing well before the treadwear comes up.
These are cheaper lol https://www.discounttire.com/buy-tir...-ls388/p/33415
Also, they say 40k but those tires usually wear out in 20-25k, by either developing edge wear or a separation of some kind, so unless you bought the tire certs, you'll be replacing them much sooner. You can try to get the to prorate the tires at that point, but they'll probably give you only 1/4 or less of the value and then you'll be stuck in the same boat of having to find another set of tires and then paying for additional mounting/balancing/disposal, tax, not to mention your time wasted on a weekend waiting another 3 hrs at a tire shop. Best to buy the good quality tire the first time and have 3x the life with a better, quieter tire that'll probably give you slightly better gas mileage.
That's good. You'll be able to drive the car for the time being, a flat spot is horrible to endure. Dad went to Americas Tire and I have had good service from them as well. The tires on the Lex come from other shops, even so they did a flat repair for me that is
The previous owner told me they always got used tires....once I learned that I didn't hesitate. These will work for the next year or two
No use in fooling with used tires, unless you have to. You never know, they might last a long time. I bought a set of Dextero tires from Walmart for my 99 RAV4 and they have been awesome tires. I put 15K miles on them in 6 months time and I swear they still look new. They may be loud, but the RAV4 has zero sound proofing so who knows . It gives me piece of mind to have newer tires, especially passing trucks on the Interstate.
Don't trust used tires
