Air Intake Hose Question - 97 LS400
Hello,
When I was treating my throttle body with Seafoam, I pulled back the air intake hose and it ripped a little bit. Understandably the car is 20+ years old so the rubber is going to be brittle. I plan on replacing my leaking PS pump and would like to have a replacement ready since it's probably going to rip some more when I completely remove it.
I was curious if anyone knew if the Air Intake Hose (OEM part name: Hose, Air Cleaner, NO.1) is the same for all UCF10/20's. Looking at the P/N's they are indeed different (UCF10: 17881-50010 UCF: 17881-50050) however they look visually similar when looking at engine bay pics. Does anyone know if they're interchangeable? The main reason I ask is even with the aftermarket options, the UCF10's are cheaper and can be shipped with Prime.
I apologize if this has already been asked, I did do the "needful" and searched the forum using Google
Teck83 (11-10-21)
Hello,
I apologize if this has already been asked, I did do the "needful" and searched the forum using Google![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Thanks, since I'm going to try and pull a Power Steering pump from the junkyard and rebuild it, I suppose I can play around a bit since they have some UCF10s and 20s.
Where did you end up getting your hose at?
If you're in the JY, might as well be on the lookout for 02-06 Camry V6s and take the coupler off those cars.
I still have it if you're interested. I eventually found a very good condition OEM one to replace this one with from a low mileage, 95k mile snowbird car.
I bought it at a Toyota dealer, cost me $35. But its an OEM Toyota coupler and will last $20 yrs without cracking.
amanda
11-18-12 12:07 PM
