Help with ECU in ls400 95
Hi, guys i’m Assim from Middle East glad to be with you and I really want some help with my ls400 95
I changed all 6 caps in the ecu after that the obd2 works again shown the code P0100 and P0110 I checked the voltage in the maf sensor 11.35v then I checked the MAF sensor was at idle 3.83 g/s and the voltage between terminal VG and ground 1.183v finally the resistance between EVG and ground 198 ohm. Any suggestions?? Also the cruise control not working.
tylergrins
06-14-15 08:23 PM
lightz
15
10-21-14 12:52 AM
