Transmission
Old 01-27-19, 08:03 PM
Sin1UZFE
Sin1UZFE's Avatar
Default Replace tranny or live with noise?
Go used? What's a good price for used?
99 ls400
Here's why, the whining in 1st and 2nd gear is in the tranny. Other than the noise the transmission emits no other noise and shifts great, no slipping etc. Fluid was changed, but not filter. When draining fluid found no material in it.
Was thinking, live with the whine or replace tranny.
A better question would be, live with awesome performing but whining noise in 1st and 2nd gear or replace?
Old 01-27-19, 08:50 PM
kjlgpw
kjlgpw's Avatar
for which Lexus model & engine?
Old 01-27-19, 08:54 PM
Sin1UZFE
Sin1UZFE's Avatar
1999 ls400
Old 01-28-19, 11:00 AM
lextout
lextout's Avatar
get a used, they can be had for 300 bux at a wreck yard, there cheap cause they rarely break and less demand, yet a transmission for a chevy cavalier will go for at least 600 bux go figure.
Old 01-28-19, 11:01 AM
Sin1UZFE
Sin1UZFE's Avatar
haha, unfortunately the junk yards near me dont have the 98-00 trannies I need
Old 01-28-19, 10:17 PM
Losiracer2
Losiracer2's Avatar
I had the same whining on my 97' 4spd A340E tranny and a new transmission filter solved it. My old one was completely clogged with material, so it may happen 10k miles or so in the future? but for now its working great, and I've put on 3k miles since October 18' when i replaced it. Only cost me ~$20 at NAPA and came with a new gasket.
I had a failing torque converter lockup solenoid about 15k miles prior that I replaced and most likely its torque converter friction that clogged it up over time. But a new filter and a drain and fill with 2.5qts of Toyota T4 fluid fixed the whining completely.
Old 01-28-19, 10:18 PM
Sin1UZFE
Sin1UZFE's Avatar
I'll try that, ordered the gasket and filter
Old 01-29-19, 09:17 AM
Superfast1
Superfast1's Avatar
The material you see on the filter is the friction material from the clutch plates. All of the soft parts are also rock hard by now so you're on borrowed time. I bet if you drop the pan, you'll see your filter is full of the same material again. Eventually, you'll need to replace or overhaul the tranny.
tyncobb
10-30-10 03:21 AM
LS400_96
02-28-09 09:29 PM
utexas112
12
02-22-07 10:28 AM
utexas112
02-05-07 01:20 PM
white93
Performance & Maintenance
04-15-03 09:08 PM
Quick Reply: Transmission
