Rear suspension bushings?
I'm in need to replace suspension bushings on my 98 LS. Especially because I just installed airbag suspension.
The bushings are on their way out eventually, but there is one specific bushing I need to find first for the sake of setting up the air suspension correctly. When the car is dropped to a lowest driveable level, there is clunking going on in the driver rear somewhere. I've omitted some culprits, like end links as well as wheel clearance and strut issues, and the only thing left is bushings, but which one?
Again, this clunking happens at low suspension setting when traveling over bumps, rear driver's. Hopefully some of you suspension gurus can chime in.
thank you
thank you
Deegee
Suspension and Brakes
08-22-15 04:24 AM
