1992 LS400 Timing belt needs to be changed
My 1992 LS400 timing belt is way overdue for a change. Almost everything else is working well, from a non-mechanic's perspective.
Two questions:
(1) What else, besides the timing belt, should I be replacing? Chasing down several previous threads, am I right in thinking I need to also replace the water pump, 2 idler pulleys, 2 bearings and a tensioner?
(2) Where do you suggest I buy these items? I'm in Eastern Canada, and my local dealer, an hour away, is not responding to my inquiries. With next day shipping, I don't think the "where" of the supplier matters, only the "who" that they are reliable, and the "what" that the parts are good quality.
Thank you for your input. I'm looking forward to having this behind me, so I can carry on down the road with confidence again.
Two questions:
yes you should be replacing other components other than the belt itself while you have most of the front engine timing parts off.
you don't need to buy directly from the dealer, as there are many sellers online that sell the same parts lexus uses. keep reading the many threads covering this subject for more details.
you can start at rockauto.com and look for a "TB/WP kit" for your year LS400.
these are the OEM suppliers (same as if you bought from the dealer):
- timing belt is Mitsuboshi (not Mitsubishi)
- water pump is Aisin
- pulleys should be of a known Japanese brand (like NOK or NTN)
- hydraulic tensioner is Toyota/Lexus
I would also replace the cam and crank seals while there, something I failed to do which I regretted!
while there I would also replace the distributor caps (x2) and rotors (x2).
How "due" are you based on miles and years? More data will help others make decisions about how long things can last in these cars.
I don't know about the Lexus, but I just did a timing belt job on my wife's Honda minivan, using an Aisin kit. If Aisin also made a kit for the Lexus, I'd definitely look into that.
However, on the 90-94, the engines are not interference, so if the belt were to fail, there would be no permanent engine damage. Knowing this, my strategy on my old '91 is to wait either for that to happen, or for some other problem that requires me to get all the way in there. I'm currently at 17 years and 80k miles on this one.
Again, depending on your mileage, the "fan bracket" (the bearing in a cast Aluminum assembly fails) typically fails at 150-200k miles. I had to replace mine at 174k, and it would have been a great time to do the T belt too. I would have done it, but I needed to get somewhere ASAP on a trip and could not delay. Removing the fan bracket is part of the TB job, so replacing with new is no extra work, just $$.
Follow-up:
We replaced the timing belt, water pump, plug wires and serpentine belt.
Found a power steering reservoir leak that explained why I was loosing fluid, and we're going to replace the power steering pump this weekend.
Hopefully the car will pass inspection tomorrow. One resonator is leaking right where the pipe enters it, due to rot, and I'm hoping they will just cut it out and put in a straight pipe, since I can't find a resonator anywhere.
Getting ready for a 3 month road trip!
Thanks again for the input.
Would someone tell me what is a recommended sealant to use when water pump is replaced on 94 ls400 , nothing came with the pump. Dealer changed it last time and black sealant was used by them .Thanks
Distributor cover.
It exhibits cracking and can fail at any time.
Should it break while under way...the engine stops turning the power steering pump and power vacuum assisted braking is lost after one pedal pump.
Since failure is without a 5 minute warning, depending on the driving situation,. this can become a real safety issue.
Never mind the towing charge and inconvenience
Surveyed a 1993 timing belt by removing plastic
Distributor cover.
Distributor cover.
I have used 2 full Aisin kits from Rockauto and I bought a lexus oem timing belt tensioner. All quality parts with ntn bearings. Super cheap on RockAuto, $150. While you're in there, replace the camshaft and crankshaft seals. Buy lexus/toyota seals. Check all your accessory bearings; idler, radiator fan, and the like. If you're willing to spend a little extra time and money, also replace distributors (2), rotors (2), spark plugs, and spark plug wires. They're right there and easy to get to. Check valve cover gaskets for seepage and replace those along with the spark plug tube seals. Especially check for oil getting into the spark plug tubes, you don't want that. Another thing is the temperature sensor that goes to the ECU, located toward the passenger side on the front of the engine. Super cheap part, very worth replacing. Be prepared to also check vacuum lines and to clean clean CLEAN as you go along. There's going to be a lot of dust, dirt, and grime. Good luck! Take care of the car and it will never fail you.
oldskewel (07-29-19)
PjLex
48
06-28-21 06:52 PM
PjLex
09-03-15 11:46 AM
d1drift
12-05-06 08:03 AM
