1998 LS 400 Owners who resolved bad ECM/ECU
Hi - I have a 1998, LS400, and after some troubleshooting and repairs, and checking OBDII codes, I have determined I need to swap the ECU.
I've obtained a good, low mileage ECU - part number 89662-50010. I now need to swap.
I have read a lot of posts on this, and they cover many years, as there are some differences both in ECU's, key transponder requirements, key challenges, etc...
What I am looking for is a little advice as to the EXACT steps I need to take to swap out my old ECU/ECM and replace it with this newer good one.
I am using the word ECU and ECM interchangeably here, as different posts I've read use both terms. They are one and the same.
Requirements vary from year to year, but I need to get a quick write up from someone who owns a 1998, and has addressed this problem before.
Among my questions are the following:
1. Is there a step by step process for the swap (not the physical aspect of location/unplugging and connecting the new one - as that is easy), but the sequence of events you need to take to activate the new ECU? If so, can you provide detail as to exact steps you took?
I don't want this to turn into an ongoing nightmare, as I rely heavilyon my car for daily use and really need to avoid any unforeseen circumstances.
2. Will my key require re-programming to be compatible with new ECU/ECM?
I guess that's it for now... I very much thank you in advance for any guidance you can provide.
Thanks,
Rob
Thanks,
Rob
Just swapping out the ecu wont work. The new ecu will not recognize your keys. To use the new ecu you can either have it flashed or you can swap the immobilizer chip from your old ecu.
JohnGalt1 (05-14-21)
