Wheel Hub Screws
since these photos are up, I have a question about the holes in the rotor.
So I purchased a set of winter wheels/blizzak tires and the wheels (Sport Edition A8-2) don't cover the brake rotor completely and I can see some of those holes exposed. Should I be worried about salt and water going past those holes, accumulating and corroding the drum brake assembly inside the hat of the rotor?
yes there is only two per rotor, but the rotor has 10 provisioning holes for them for easy quick install.
they are only there to assist in keeping the rotor on the hub during installation of the calipers.
they are NOT the main component to keep the rotor from spinning free - the studs are!
nissan does not even have these rotor screws so when you remove the wheel, the rotor sometimes just dangles there and the caliper keeps it from completely falling off.
it's a floating rotor design. toyota and honda puts these screws just to retain them onto the hub, in two opposing places.
i hate when they strip or rust shut!
at times you'll have to drill them out or use an impact driver and lots of penetrating lubricant!
This is the impact driver I use:
Or you can use the right tool. I used to strip some until I realized the big difference between American and Japanese screws and got my Japanese Industrial Standard (JIS) screwdrivers. Haven't stripped any since.
https://www.amazon.com/Vessel-Megado...=fsclp_pl_dp_1
https://www.sears.com/craftsman-2-pc...p-00986616000P
It says Phillips #2, but it's actually the JIS version. These are made in Japan. Very nice.
Fit1too (02-12-19)
X 1miilion on the JIS screwdrivers,They are NOT Phillips.
I have this,can get some nice torque with it
Motion Pro T-Handle Bit Driver with No. 1, 2 & 3 JIS Cross-Head Bits 08-0557
by
l Black l
Wheels, Tires & Brakes Forum
12-02-07 12:57 PM
