NEED HELP _ engine revs and smokes at startup
1995 LS400. Got it cheap to rebuild. Overhauled engine - did valve job, replaced gaskets, water pump, timing belt, injectors, spark plugs and wires.
Now when I start it - it starts up and engine revs up to 2000-2500 rpms and stays there. Also there is blue/black smoke comes out of exhaust - a lot!
I've replaced ECU 3 times! Original was leaked and damaged.
1st one used and I re-soldered capacitors on it. No effect.
2nd one was used from online store. No effect.
Got donor wrecked car (I drove that car - no problem with engine), pulled ECU from it and installed. No effect.
Also pulled the Idle Air Control Valve from donor and put it in a car. No effect.
Cant figure it out. No codes showing and no CEL.
Can it be that new injectors are always open?
Thanks
Thanks
it could be as simple as a vacuum leak leading to a high idle.
blue/black smoke is oil burning, which could be from the power steering IAC valve which tends to leak and causes PS fluid to get sucked into the intake tract and burned.
why the overhaul on the engine? not holding compression?
When I've got it it was working rough with white smoke from exhaust. I assumed it was head gasket and I was "eh, screw it, I will overhaul it" since I was planing to keep it for my pleasure riding. Still do. So overhaul looked promising. I've done a lot of V6s like 1MZ-FE but this one is tough. By "overhaul" I meant valve job, gaskets, water pump/timing belt but NOT new pistons/rings/bearings. It is only 96K on it.
I'll try to re-check all vacuum lines. Again. I don't think it is oil burning, as it strongly smells half burned gasoline. I know about power steering thing so I will check it too. Maybe it is a combination of several things.
Is there any tricks to see if ECU is properly working?
Thanks.
Thanks.
Sorry Timmy, didn't see your post!
Thanks.
Thanks.
swiggins
05-06-07 08:18 AM
