Ride suddenly getting harsh
My 1998 LS400 has started riding very rough. It absorbs bumps just fine, it's that I can feel every little bump in the road and the shock and vibration come straight into the steering wheel.
About 10000 miles ago I replaced all the shocks on all four wheels, kept the stock springs (southern car, no rust looked brand new if not dusty), replaced the upper and lower control arms in the front and got an alignment. I ordered the parts from rock auto and am worried the quality is far worse than I expected (Edit: looked up my order they are Mevotech and should be okay quality). I knew they wouldn't be Lexus OEM quality but 10,000 miles is garbage. I recently had to drive on a very bumpy gravel road.
Does this sound like maybe ball joints? It definitly feels like the shocks and springs are fine but the interface between the wheel and the shock is bare metal if that makes sense.
What shocks did you put on?
The front lower ball joints are a potential problem area and wear more quickly than they otherwise would.
Have you replaced the front strut rods? Do you get clunking?
https://www.clublexus.com/forums/ls-...-thread-9.html
I believe I found the issue or at least found something else that needs to be fixed anyways, bushings on the strut rod are looking trashed. Thanks for the reply though!
