Car has no power, I’ve replaced coils and ecu
Changed alternator, coils and still running bad
Changed alternator, both coils and still running bad and has no power , I just recently deleted the middle mufflers with straight pipes , I kept the cats and it has straight pipes from cats to the back mufflers, could that have messed something up
Sensors back there still in place? Did it happen right after the muffler deletes? No codes?
You might try to remove the upstream oxygen sensors and do a test run to see if power has returned. If power returns, you have a clogged cat. If power doesn't return, you don't have a clogged cat. Test drove will be noisy.
