Ps pump and water pump
I ended up getting used alternator and ps pump both oem. With 90 day warranty!
Just need to find a water pump. Same donor car has one in great condition....for 40 and oem according to my mechanic buddy
Or
https://www.rockauto.com/en/catalog/....0l+v8,1356083
Or
Is the existing PS pump leaking? Is the water pump leaking? I ask because replacing used parts with used parts is basically futile. A wrranty on used parts is basically useless as well. I doubt they have a back stock of Lexus Ps pumps and alternators to honor any warranty. Even if they refund your money, which I doubt will happen, you're still stuck with a failing used part that needs replaced AGAIN...
Unless I've missed something you still haven't disclosed the reasons for replacing these parts. The PS pump and Alt are common service items but that doesn't necessarily mean jump in and replace them JUST BECAUSE...
Ok is the PS pump leaking or the Air Control Valve? Both are common. Even a brand new $450 Lexus pump with an old valve may still leak. Throwing used parts, genuine Lexus or not, at the problem isn't going to solve anything. I wouldn't even consider spending money or time on ANY alterntor until the PS pump situation is fixed 100%. Find the source of the leak, whether it's the pump itself, the air control valve or maybe even the old brittle hose between the reservoir and pump, and address it accurately or this will never end...
Its leaking from the pump itself not the valve. The new to me ps pump will have that valve deleted before installation. Also ordered an aisin water pump as it's also leaking...as such it leaked all over the alternator. Thus the replacement. Once new ps pump is in place I'll have the old one rebuilt using a n oem kit above.
Sorry to keep badgering you with questions but I've been down the PS pump road with my 91 AND my 99. It's not fun and takes some time. Both cars weren't fixed, after all the trials and tribulations, until I installed brand new Lexus PS pumps.
Is the bold underlined sentence in the quote a typo? How did your water pump leak all over the alternator...? Only the very far edge of the water pump is anywhere near the alternator and they generally only leak through the bearing and shaft not the gasket.
This is starting to make sense logically...
