Oil leak from front of engine 1998 LS400
Have you removed the engine cover? Oil leaks really aren't hard to track down once all the plastic is out of the way. Worse case you might have to remove the metal cover over the cam pulley.
The valve cover bolts have a very low torque spec, 53 INCH-lbf so it's fairly common for them to come loose. Sometime they just need tightened a little...
Now that i think about it. About 6 months or so ago i did tighten down my valve cover bolts on drivers side because i suspected a leak and 2 of the bolts seemed loose. Its possible i may have over tightened the top bolts of the valve cover. none of the lower bolts show any signs of leaking. I have removed the engine cover, but its still hard to see that top left bolt
saleenssc (03-19-19)
dbui
RX - 1st Gen (1999-2003)
06-03-15 05:37 AM
lexie
08-11-08 03:19 PM
