Timing Belt Replacement URGENT
Hi All,
So I just did the Timing Belt on my '99 LS400... And I have a sporadic CEL for P1349 and P1351 (VVT Camshaft Position Sensor Range/Performance Problem.) The codes are bank 1 and 2 codes. They will appear a day or two after clearing, and no operational issues are noted with the engine AFTER the change, It runs great, but with a noticable performance change. I'm lucky in that regard... Phweew...
Anyways, I am a first year apprentice with Toyota, so I have access to TIS and Techtool etc, followed the instructions to the tee (and boy do they make you jump around). I haven't pulled everything apart to check the timing yet but will be doing so today and/or tomorrow. So here are my questions...
1. With the Crank set to 0* (TDC), the notches on the sprochets should line up with the LINES?
2. With the Engine/Pulley advanced to 50* ATDC (Idler Pulley Bolt, as per instructions), the Notches should line up with the T that is to the right of the LINE?
3. What is the Torque Spec for the Bolts on the Ends of the Cams. I accidentally loosened one and couldn't find a torque spec for it...
4. Can I adjust the Timing of the Engine WITHOUT Removing everything again (ie: Can I remove the Upper Cam Covers and the tensioner, and get away with it that way?)
Update,
Pulled #3 T/C Covers off (Upper0), Both Cams late by 1 tooth. Confirmed theory of skipping on the crank pulley. So my question now is how much room is there for the timing to be off before damage/destruiiton can occur? The engine runs great as-is.
ALSO: If you don't know what you're talking about, I don't want any "You're Screwed" comments. Serious only please!
Hi All,
Update,
Hi All,
You want to release the belt tension and move the pulleys into the appropriate place. I guess you could try and if it doesn't work there's only one alternative. I've never heard of anyone doing so...
I used Aisin parts (Being that they are Toyota parts with the branding scrubbed off), and you are probably more than right, any serious internal damage would long be done by now as I have driven around 200kms with it like it has been and haven't noticed a single thing aside from a slight drop in performance and the obvious check engine lights.
That being said, I guess I'm gonna have to tear the front apart again this weekend and re-time it! :P Thanks for your help!
I found 2 different videos on how to set TDC, Hopefully they will help you:
and
Those bolts on the end of the cams don't have a torque spec. They seem to be there to assist in turning the cams for timing. Don't over torque them, just snug them up.
Update,
cocora64
05-30-08 04:43 AM
