Exhaust Gasket Part Number
Can someone say me whats the gasket between Exhaust Pipe and Catalytic Converter? I suspect mine is probably leaking so I would replace both the exhaust gaskets. Also is it a DIY or pay a shop to do it? I suspect the car is from California and look okay on the Cats, the bolt might be stuck deep. So.
Also can i apply a JB weld and seal it off instead of replacing the gasket otherwise?
Part number for L and R gasket's then? 1998 LS400 and California if that matters
First time I did it, I bought new gaskets and put a little Permatex Ultra Copper on(still had leak). Second time I tore it apart, I reused the gaskets and used a lot of the sealer. I took pictures of the after shot if you're interested.
The reason I don't think the gaskets matter that much, is that the first time I changed out my gaskets to fix the leak- the leak was actually much worse after I had cleaned up the flange of corrosion and installed new gaskets.
Sherl (03-29-19)
On this thread around post 127 and 128 you should see pictures of what I was talking about. As to part numbers, I just went to Lexus and ordered them there. I also have a 1996 and think the numbers changed for the 1998. You could also just go to AZ. I don't think the quality of the gasket matters as much as using liberal amounts of the Permatex.https://www.clublexus.com/forums/ls-...w-owner-9.html
Two bolts hold the rear part of the cats on both sides, so you would need to take off 4 bolts(and one in the rear if you wanted to take the Y pipe off entirely. If I remember right I had to cut off one of the bolts because I rounded off bolts on disassembly. Probably depends on how rusted those bolts are as to whether you could handle this.
This stuff might be better though. The copper stuff only goes to 700F intermittent. This stuff goes to 2000F, Permatex Muffler & Tailpipe Sealer
https://www.acehardware.com/departme...4aAnoBEALw_wcB
qewani1
01-25-10 04:01 PM
