Shifter Hard to Shift From Drive Back Into Park
I have a 97 Lexus LS400 which I have owned since it was a year old. Recently, I've noticed the shifter is hard to shift from Drive back into Park. I think it may need some lube. Just wondering if anyone has also experience the same issue. Thanks.
https://www.clublexus.com/forums/ls-...-bushings.html
https://www.clublexus.com/forums/ls-...r-plate-2.html
The shifter mechanism internals require lubrication...and after 20+ years the lubricant is expired.
Consider replacing your shift indicator plate while servicing.
Bogey2 (05-20-21)
I was going to replace my shift indicator plate last year as it has started to de-laminate (bubbling). I have called a few dealers but was told Toyota no longer make them.
