Is this the culprit?
I've read a lot of threads on the 65 mile-an-hour shimmy as that is exactly what I've had since I bought this car a year-and-a-half ago a 99 LS with 77k on it now. I have the OEM bushings and a friend with a press. I know I have to break down and do this job. Just want to hear you fellow club members encouragement and if you think these are heavily Worn.
Use OEM. Aftermarket parts may degrade ride
Rreplacing only bushings, you can save a few $$.however they must be indexxed.
Replacing the the entire arm prevents possible missteps.
Suspension fasteners must be tightened with full vehicle weight on suspension, or bushings will tear.
Vote for replacing. Please share process it ya can. Thanks
Hey Yodaone,
Does this apply to all vehicles? I recently replaced some sway bar end links on my other car(04 Mitsu Galant) and I am getting a rattling similar to worn end links. I tightened with the tire off and one side lifted at a time. Thanks for the tips.
-Giorgio
-Giorgio
I cannot promise I'll doc the process, but i'll definitely report my experience when I finish.
Is it time and usage that wear these out? With all deserved respect (Toyota-Lexus) I say this next...Or is it designed to fail? This car spent it's life in a scientists garage in Raleigh NC used for trips to Florida and Hilton Head SC. It's not like it was running the Baja 1000 or climbing Pikes Peak! I did read at one point here that it could be the extreme torsional stress on them that contributes to failure. I think that, and it's possible softer compound, engineered in, to give it that LS ride. My thoughts. What do you think?
the reason for rubber bushings is so you can enjoy driving your car, THEY FLEX, iron and steel would make for a very lousy ride SO YES they are designed to fail so your butt wont..... and if you have to be told yours are worn out, just keep on driving and the car will let you know. time and age are your enemy...
my 99 LS is solid as a new car
230k miles
lower ball joints, lower control arms, strut rod bushings (twice), all tie rod ends, rack and pinion, rotors and ceramic pads (twice), and new under engine splash shield on the front end along with a radiator and two WP&TB kits... have owned it 10 years, love it..
230k miles
230k miles
Bad Idea?
since you'll be down there anyway, i suggest doing the front sway bar bushings
https://www.clublexus.com/forums/ls-...-bushings.html
it's honestly a very easy thing to do with an immediate noticeable improvement in handling, takes like 5 min to swap out the bushings (excluding getting it up in the air and removing the front splash shield)
400fanboy (05-03-19)
