Alternator Pig tail
Old 05-02-19 | 08:59 AM
jcdickson1's Avatar
jcdickson1
Unhappy Alternator Pig tail
My alternator clip is no good. Looking to purchase a new clip. Does anyone have a diagram that denotes the colors of the wires for the clip that goes in to the alternator.
Old 05-02-19 | 10:36 AM
YODAONE's Avatar
YODAONE
Year?
If wires and contacts are intact, do not use a "pigtail".
Simply replace the plastic connector shell and avoid cutting up your wiring harness.
Maintain the same wiring order.
Contact your Toyota or Lexus dealer to order this part...inexpensive.
The following 2 users liked this post by YODAONE:
Giorgio13 (05-02-19), jcdickson1 (05-03-19)
Old 05-02-19 | 02:23 PM
Giorgio13's Avatar
Giorgio13
Wiring diagram for a 95 LS, charging
I agree with Yodaone...he seems to have alot of good advice so stick to replacing that connector.
Old 05-02-19 | 04:09 PM
YODAONE's Avatar
YODAONE
The wiring diagram is great..but if you misindex the order....then may cause more expensive damage to other electronics.
If contacts still inserted into remnants of old plastic shell to guide you, otherwise seek assistance
Old 05-03-19 | 09:49 AM
jcdickson1's Avatar
jcdickson1
My car is a 1997 ls400. Three wires the connect is bad. one yellow wire one red and black the other is brown and discolored. I don't have the orientation of how they were in.
spuds (05-03-19)
Old 05-03-19 | 12:19 PM
jcdickson1's Avatar
jcdickson1
Just picked up a new connector. Can some one tell me the wire order based one colors of the wires. My wires came all the way out of the connect and I didn't get a picture of the orientation
Old 05-03-19 | 05:15 PM
oldskewel's Avatar
oldskewel
If you look inside that new connector, do you see a 1-2-3 cast into the plastic? If yes, those probably correspond to the 1-2-3 shown on the circuit diagram.
E.g., for that 1995 diagram,
1 = Y = yellow
2 = B-R = black with a solid red stripe
3 = W-L = white with a solid blue stripe
And the arrows (>>, like a chevron) in the diagram indicate the actuall connector there. So if instead of 1-2-3 inside the connector you see 6-2-10, you can see what that means as well.
So you need to find a similar diagram for your '97, or you could make some assumptions based on what you've got already.
jcdickson1 (05-06-19)
Old 05-06-19 | 03:51 AM
jcdickson1's Avatar
jcdickson1
Fixed it. The diagram you all provided helped! Thanks so much. Now I have to tackle getting the front end fixed. Tie rods, ball joints etc.
Giorgio13 (05-06-19)
Old 05-06-19 | 08:42 AM
Superfast1's Avatar
Superfast1
Did you get the connector from the dealer? Please provide the p/n.
Old 05-06-19 | 01:27 PM
YODAONE's Avatar
YODAONE
Default 1995-2000 ls400 alternator connector housing p.n.
If your alternator wiring and connector contacts are intact, but plastic housing is broken, then all you should require is this housing.
Each time I disconnect something underhood, the wiring harness side connector housing is brittle and breaks no matter how careful. Purchase housing(s) before performing work.
Old 05-06-19 | 01:59 PM
Superfast1's Avatar
Superfast1
For 97 LS400, my search came up w/ 27060-50190 or 27060-50230 or 27060-0D010. Are they all interchangeable?
Old 05-06-19 | 04:21 PM
Giorgio13's Avatar
Giorgio13
Hell yeah man. Glad it helped you. I got the wiring diagram from alldatadiy.com which provides techinal information for 25 bux a year. Additional vehicle subscriptions cost 20 bux after your first.
clantonls4
05-21-23 11:58 AM
RLJ
Performance & Maintenance
06-12-17 07:51 PM
jscoda
08-07-14 02:40 AM
SDDrewGS4
Performance
06-30-10 04:36 PM
Quick Reply: Alternator Pig tail
