Cant find 1991 ls400 rear stabilizer bar bushings anywhere need help
I Order from Daizen but they refunded the money i guess they dont have em in stock and Kendall Lexus did the same thing, Refunded the money where can i find these ??
Yea i think thats what I'll have to do because i called every Autoparts store and i tried online and it's impossible, i think the diameter is 20mm for the rear so I'll get some generic/universals i guess. Thanks for the Help
Is this what you need? Amayama are good folks too.It does say 1992 tho....their site says 1991 out of production,could a 1992 possibly fit?
Genuine Online Car Parts Catalogue Lexus LS400 UCF10L UCF10L-AEPGKA Transmission and chassis Rear spring & shock absorber
Here are parts you've selected:
NoPNC#
(SUB)OEM part numberRequired
per carProduction periodNameApplicabilityPlease order in advance
0148815R48815-500300205.1989 - 08.1992BUSH, STABILIZER (FOR REAR)UCF10
0.00 USD
0248815R48815-500700208.1992 - 10.1994BUSH, STABILIZER (FOR REAR)UCF10..USA
W(AIR SUSPENSION)15.28 USD
0348815R48815-500800208.1992 - 10.1994BUSH, STABILIZER (FOR REAR)UCF10
15.28
to 17.92 USD
More than 1 spare part found. Please define it more accurately before ordering.
Click on the part subgroup below to get genuine part numbers.
Click part number in the scheme or in the list:
48750A NUT (FOR REAR SUPPORT TO REAR SHOCK ABSORBER)
9411041000 ** Std Part
48553A CAP, SHOCK ABSORBER
48257B INSULATOR, REAR COIL SPRING, UPPER
48750G NUT (FOR REAR SUSPENSION SUPPORT)
48755 SUPPORT, REAR SUSPENSION
48080B NUT (FOR PNEUMATIC CYLINDER REAR)
48341 BUMPER, REAR SPRING
48530 ABSORBER ASSY, SHOCK, REAR RH
48231 SPRING, COIL REAR
48815R BUSH, STABILIZER (FOR REAR)
48540 ABSORBER ASSY, SHOCK, REAR LH
48824R BRACKET, STABILIZER (FOR REAR)
48080 CYLINDER ASSY, PNEUMATIC REAR RH W/SHOCK ABSORBER
48090 CYLINDER ASSY, PNEUMATIC REAR LH W/SHOCK ABSORBER
9011908588 ** Std Part
48258A INSULATOR, REAR COIL SPRING, LOWER
42304B NUT (FOR REAR AXLE CARRIER)
48812 BAR, STABILIZER, REAR
9020114020 ** Std Part
48770C BOLT (FOR REAR UPPER CONTROL ARM)
48830A NUT (FOR REAR STABILIZER LINK)
42304A BOLT (FOR REAR AXLE CARRIER)
9017014012 ** Std Part
48730A ARM ASSY, REAR SUSPENSION, NO.2
48190R CAM ASSY, CAMBER ADJUST
48830 LINK ASSY, REAR STABILIZER
48725B BUSH, REAR SUSPENSION ARM, NO.1
48198R CAM, REAR SUSPENSION CAMBER ADJUST, NO.2
48703E BOLT (FOR REAR SUSPENSION ARM)
9017014023 ** Std Part
9338215012 ** Std Part
48770A ARM ASSY, UPPER CONTROL, REAR RH
48790 ARM ASSY, UPPER CONTROL, REAR LH
48737 COVER, REAR SUSPENSION ARM, RH
9017914015 ** Std Part
42304 CARRIER SUB-ASSY, REAR AXLE, RH
48738 COVER, REAR SUSPENSION ARM, LH
42305 CARRIER SUB-ASSY, REAR AXLE, LH
48725E BUSH, REAR STRUT ROD
48703C NUT (FOR REAR SUSPENSION ARM)
48780A ROD ASSY, STRUT, REAR
48780B BOLT (FOR STRUT ROD)
48780C NUT (FOR STRUT ROD)
48710A ARM ASSY, REAR SUSPENSION, NO.1 RH
48720A ARM ASSY, REAR SUSPENSION, NO.1 LH
Lexus LS400 genuine parts
Information is provided by the epc-data.com and is not guaranteed to be correct in full.
Car partsInformation
© 2004-2019 «Amayama Trading Co., Ltd»
Rear spring & shock absorber for LS400 UCF10L
NoPNC#
0.00 USD
15.28
to 17.92 USD
Ya think so? They look good enough for now but the bushing on the strut rod (the 5056) is cracking and deteriorating, I can't really see the 505 on the axle carrier. Some look good but, I can't shake them from here.
I thought something was wrong for a second looking at the camber adjustment. I was thinking "why is that crooked?" (brain freeze) Those look like they are starting to crack also.
Must be nice to just throw the car on the lift whenever you want.
AlaskanLS
03-02-19 09:17 PM
micronesia
09-24-10 09:22 PM
DoubleWhoosh
13
02-15-06 09:36 AM
